Dim Lights
Old Jan 20, 2005 | 11:53 AM
HollywoodF-150's Avatar
HollywoodF-150
Dim Lights
I have a 94 F-150 maybe I am doin something to much and am going blind but I am sure my lights are getting dimmer. i used to get high beamed on low now I don't ever get flashed, even on high.
Ever heard of this? Does any one know the voltage that is supposed to be at the lights? They are aftermarket lights about 2-3 years old, i wouldn't think that would matter.
Oh yah if I am on high beam and I have the ebrake on a little they are dimmer than when the ebrake light is off, doesn't make much sense to me, hopefully someone and help
thanks
Old Jan 20, 2005 | 04:38 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Check voltage at battery with the engine running.
Old Jan 20, 2005 | 05:30 PM
HollywoodF-150
I have checked that it seems the lights aren't getting enough power, I havn't check how much is at the lights yet but I know something isn't right.
Old Jan 20, 2005 | 05:54 PM
sphinx's Avatar
sphinx
Check your headlight switch. I rewired my headlights this last weekend so they used relays and draw power directly from the alternator. If you do a search you should come up with something.
frank7mm
Nov 28, 2012 03:27 PM
Weezman
1978 - 1996 Big Bronco
Sep 9, 2008 05:04 PM
petelynch
Jun 13, 2007 11:39 PM
eman resu
Electrical Systems/Wiring
Feb 20, 2007 08:56 PM
opjgeorge
Oct 29, 2002 01:48 AM
