Need help with driveshaft!
Old Jan 20, 2005 | 07:55 AM
faroffthetrack's Avatar
faroffthetrack
Exclamation Need help with driveshaft!
Could someone please explain to me how remove the second half of the drive shaft on my truck (behind the bearing), or do i have to take the whole thing out?
http://img.photobucket.com/albums/v5...3551331205.jpg
I can slide the thing out but just to hear, then it stops.
http://img.photobucket.com/albums/v5...3551351813.jpg
-Thanks!
Old Jan 20, 2005 | 09:00 AM
wtroger's Avatar
wtroger
If I remember right I believe that collar where the grease zerk is will unscrew from the yolk then you can finish pulling drive shaft.
Old Jan 20, 2005 | 10:57 AM
Chuky66's Avatar
Chuky66
It doesn't unscrew. I just did a 86 and a 89, and it is just hard rubber that sits in a lip. You can try bumping the shaft off with a mallet, or pop off the grease cap and it will slide right off. The splines are hitting on the seal.
The carrier bearing is the real pain to remove!!!!
Chuck
