1986 Tilt Steering
Old Jan 19, 2005 | 09:26 PM
Biff1's Avatar
Biff1
1986 Tilt Steering
Anyone out there ever do a swap from non tilt to tilt ? I would like to change my 1986 F150 to tilt. What all would it take ?
Thanks
Old Jan 20, 2005 | 08:08 AM
ronclark's Avatar
ronclark
Find a tilt column from a junker. It will bolt right in. If you want to use the same ignition key then you will need to swap the key cylinder
Old Jan 20, 2005 | 09:37 AM
Biff1's Avatar
Biff1
tilt steering
What years will fit? Mine truck is 1986.
Old Jan 20, 2005 | 10:16 AM
ronclark's Avatar
ronclark
1980-1986 will fit not sure about the 87-96. Junk yard should be able to tell you.
Old Feb 8, 2005 | 09:23 AM
hermangarza's Avatar
hermangarza
is it a direct bolt in out does it requiere some modding?
thanks
Old Feb 8, 2005 | 12:18 PM
ronclark's Avatar
ronclark
No mods required as long as you get an auto trans version to replace an auto trans and a manual version to replace a manual. Only difference I found when I swapped mine was the wrap around plastic molding where the column fits against the dash. Might want to grab that while at the junker.
Old Feb 8, 2005 | 12:28 PM
hermangarza
what was needed to be removed, wheel, dashboard?
thanks
Old Feb 8, 2005 | 12:35 PM
ronclark's Avatar
ronclark
To remove the column.
1. remove the bolt under the hood where the column attaches to the steering sector and disconnect the shift linkage rod from the column.
2. remove the plastic collar from around the steering column where it attaches to the dash (2 screws) This is the collar you need from the junk yard.
3. Remove the 2 bolts that attaches the column to the dash.
4. let the column drop down and remove the wiring from the ignition switch and turn signal
5. remove the screws that attach the base of the column to the firewall and remove the column.
