Rear diff swap???
I have a 99 2wd 2.5L reg cab(el cheapo model) with 7.5" axle and 3.73 gears. I would like to go with slightly bigger tires (235 75 15?) but I mainly want to get into some sort of limited slip. If I went with bigger tires, I think I'd like 4.10 gears also, to slow it down a bit.
I am currently thinking I'd like to find a complete axle somewhere. I could fabricate new mounts, etc if necessary, but would be leery of adjusting backlash,etc.(heard it's not a DIY kind of job). It would be nice to just bolt it in, though!
Do you think I'm crazy or what? What kind of donor vehicle should I be looking for. Any other ideas??
TIA, Jim
Dave
TIA, Jim
Trying to remember from 'the ole days' - when the tire size increases, you are changing (theoretically) to a 'higher' ratio (lower number gear).
By swapping out the 3.73 for a 4.10 you won't gain anything (much). The only gain would be IF you kept the same size tire/wheel combination.
Yes, you would get out of the 'hole' faster, but, the 'top-end' would be less, because of the hp, torque and gearing, only if the tire diameter is the same, or smaller. (I didn't see what the original tire size was.)
Anything more than 4.10s and that 4 cyl will be huffin' and puffin' in short order.
The 235/75-15s might not make any difference, in which case, it would all go back to the LS option.
cost and lsd are the other factors in this equasion.
Thanks, Jim
Thanks, Jim
I've don't have much experience with the different size(s) of rearends in Fords, such as 7.5 vs 8.8. I do have quite a bit of experience with other rears, though.
(In my younger days.)
IF you could find a 8.8 rear, I don't know why it wouldn't bolt up. If this is wrong, I stand corrected. (Other input????)
As for installing the gears for 4.10s, you MUST set them up correctly. The pinion depth needs to be right, the ring gear 'backlash' has to be right, otherwise you will either go from a little noise in the rear up to galling teeth, causing the metal to lose their heat treatment, all the way to include breaking teeth on the gears.
IF you could fine a junkyard with 8.8 set-up with 4.10s already installed, that would be the way to go.
There is always "Currie". They can build you a rearend, set-up and ready to go. (That's $$$$$$$$, though.)
Last comment. . . as for the 3.73s being 'too fast', just let-up on the gas.
(Sorry, I HAD to say that.)
Yes it is a direct bolt up. Look for an 8.8 out of a v6 ranger with 4.10 LS and good brakes and it will replace the 7.5 housing/diff/brakes/etc. Its about a 3 hour job with a lift. A little longer with jack stands. Also manny more 4 wheel drives had the 4.10 in them, they will also fit.
Dave
