fUEL GEL
Old Jan 19, 2005 | 08:56 PM
sterling's Avatar
sterling
fUEL GEL
At what temp does fuel start to gel??
Old Jan 19, 2005 | 11:01 PM
77hiboyboy's Avatar
77hiboyboy
depends on your fuel blend.
Old Jan 20, 2005 | 09:26 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Straight (no mix, no additives) #2 will start to cloud at around 20*F
Old Jan 20, 2005 | 09:28 PM
sterling's Avatar
sterling
is that 20 above....?? Wow
Old Jan 20, 2005 | 09:41 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yep, but in the winter time you likely won't find straight #2. In the northen third of the country and Canada you can get Straight #1 or even a #1 DF-A blend that's good to anywhere between -20 and -60. Down south we get #2 with an anti-gel additive, get's pretty dicey around 0, luckily that almost never happens.
Old Jan 20, 2005 | 09:55 PM
sterling's Avatar
sterling
Thank you sir
