1978 - 1996 Big Bronco
help alternator problems
Old Jan 19, 2005 | 08:53 PM
schrubmeister's Avatar
schrubmeister
I need help, tonite I put a new battery in my 88 and accidently got it backwards but it only touched once and sparked then I figured out my goof, problem is now my alt. is dead. My question is is there a fuse or something that would blow or is my alt. dead?
Mike
88 EB Bronco 302
01 S-Crew 4x4 5.4l
Old Jan 20, 2005 | 12:44 AM
greystreak92's Avatar
greystreak92
The inverted connection has the potential to kill the diodes in the alternator. If they are fried, the alt. is headed for that big rebuilder in the sky. Best thing to do would be to yank the alt. and have it tested.
Old Jan 23, 2005 | 07:28 PM
BroncoRoadKill's Avatar
BroncoRoadKill
you may have just blown a fuse link.
Old Jan 23, 2005 | 08:24 PM
Trublufords's Avatar
Trublufords
Check for power on Bat terminal on back of alt- if none the fuse link prob has melted-blown.Link is made in wire and is usualy comes(feed) off post on starter solenoid (bat voltage)- pull on wire,( has a 3/4 in.long rubber block with guage-amp stamped on it) and if burnt will pull apart.Fuse link wire can be bought at any parts store- you will need a wire eye terminal, a section of fusable link wire and a heat shrink wire tube connecter to install. Hope this helps!!!
Old Jan 24, 2005 | 10:26 PM
schrubmeister
Thanks for the info I'm gonna look at it this weekend and see if that's the problem , I sure hope so.
Mike
88 EB Bronco
01 S-Crew 4x4 5.4l
540milotalon
Aug 15, 2016 11:31 AM
allhuntalltime
Oct 26, 2015 06:45 AM
84&04
Sep 2, 2015 08:12 PM
84&04
20
Aug 28, 2015 06:24 PM
nonoodlez
Feb 28, 2015 11:07 AM
