Transfer Case Switch not working. Tests?
Old Jan 19, 2005 | 07:06 PM
95se5m's Avatar
95se5m
Unhappy Transfer Case Switch not working. Tests?
Hello all,
My wife's 1992 Ford Explorer had a working 4wd till last week. The switch seems to work, the 4x4 light on the dash is on. When you hit the button, you do not hear the small click of the motor engaging.
I was wondering if there is any testing procedure to make sure the unit is actually bad since the new one is $150+. Any thoughts or direction would be appreciated.
Vehicle info:
1992 Ford Explorer 4WD
Warn manual hubs
Electronic 4WD
Automatic
Jim
Old Jan 20, 2005 | 05:22 AM
marragtop's Avatar
marragtop
Try putting it in 4x4 Low first, then regular 4x4. I've seen where that works sometimes. Also, there are many postings and links on this forum regarding this.
Mike
