no head lights
Old Jan 19, 2005 | 06:54 PM
bobkatcurtiss's Avatar
bobkatcurtiss
no head lights
have a 92 e250 300/6 went to turn on the head lights and no lights,went 2 the ford place and thay sold me a new light switch, installed the new switch and still no head lights,,, the only lights i have is high beams when i hold the turn signal back.. and no high beams when i push turn to high beams...could the switch in the turn signal for the lights be bad?? thanks for all your help.............
Old Jan 19, 2005 | 08:57 PM
rssengstock's Avatar
rssengstock
Sounds like anothe bad multifunction switch........ These electronics must be made in Taiwan or something.
Old Jan 19, 2005 | 09:34 PM
Franklin2's Avatar
Franklin2
Yes, and as stated above, Ford calls it the "multifunction switch".
Old Jan 20, 2005 | 04:13 PM
HollywoodF-150's Avatar
HollywoodF-150
what is a multifunction switch? Could that make my headlights dimmer?
Old Jan 21, 2005 | 08:05 PM
Franklin2's Avatar
Franklin2
The multi-function switch is the turnsignal, high/lowbeam, hazard, and maybe a couple of other things all combined into one switch.
Old Jan 22, 2005 | 02:31 PM
HollywoodF-150
Found the problem, just a bad wire
Thanks
