Transmission ID
Old Aug 29, 2002 | 10:46 PM
GEAH's Avatar
GEAH
Transmission ID
Is there a website that you can use to identify a transmission by the numbers on it?
Old Aug 30, 2002 | 12:52 AM
Franklin2's Avatar
Franklin2
Transmission ID
If it's an automatic, you can identify it by the pan shape. What do you have?
Old Aug 30, 2002 | 10:05 AM
GEAH's Avatar
GEAH
Transmission ID
manual of a 78 1/2ton with an np205 behind it.
c-96391 AM is stamped on it.
also 1042978
Old Aug 30, 2002 | 04:46 PM
Jimbare's Avatar
Jimbare
all alone in the world
Transmission ID
if it has an aluminum top cover, with a push down and twist cap holding the shifter in it is a new process. if it has a screw on cap holding the shifter in it is a borg warner.
Old Aug 31, 2002 | 09:45 AM
GEAH's Avatar
GEAH
Transmission ID
it does have the aluminum cover on top. When I searched the numbers NP435's came up.
Old Aug 31, 2002 | 05:46 PM
brown 4x4's Avatar
brown 4x4
Transmission ID
