expedition heat
Old Jan 19, 2005 | 04:32 PM
mountainman101's Avatar
mountainman101
expedition heat
98 expedition front and rear heat no heat in front turn **** from right to left doesent change temp back works fine how do check this
Old Jan 20, 2005 | 06:00 AM
trike1946's Avatar
trike1946
Go the simple route first. Check the **** on the back to see if it is cracked or worn. If the back **** is the same switch it and try it. If no go check the switch.
