Aerostar Ford Aerostar
Front Differential lube
Old Jan 19, 2005 | 08:58 AM
cub 1947's Avatar
cub 1947
The Dana 28 front end on my AWD Aerostar jus went south. Two questions, first will it drop out straight down without moving the subframe?. Second, has anyone tried real axle lube in this unit instead of the ATF that Ford recomends? I just want to delay a repeat.
Old Jan 19, 2005 | 10:14 AM
aerocolorado's Avatar
aerocolorado
It will drop down without removing the subframe. It is held in place by four rubber isolator mounts whose nuts can sometimes be buggers to remove. Liberal use of penetrating oil beforehand will greatly aid your efforts. Twist too hard and you will ruin the isolator by tearing the inner "bolt head" loose from the rubber it is embedded in.
Stay with the recommended Mercon transmission fluid. If the diff failed, it wasn't because of lubrication. Perhaps a lack of but not due to.
Old Jan 19, 2005 | 01:33 PM
rebocardo's Avatar
rebocardo
I agree, stick with the transmission fluid. I changed mine every 25K along with the transfer case and transmission fluid. 187K before any repair other then brakes, shocks, and tires. Unfortunately the A4LD gave it up at 187k. I hope to fix it some year ...
