Sponsored by: Real Truck
How big a tire?
Old Jan 19, 2005 | 08:53 AM
Hjudge49's Avatar
Hjudge49
How big a tire?
How big can I go on an '05 Superduty with a 2 1/2 " leveling kit? I want to put 325/70 17's on 10" Mickey Thompson wheels. Anybody know if they will rub?
Old Jan 19, 2005 | 10:00 AM
wolffee's Avatar
wolffee
Im running 315 75R16's (35'') they dont rub at all i have an 04 F-350 SRW with a 2.5 inch leveling kit and 16x10 wheels. Good Luck Im running Goodyear MTR's I dont know what tire your running or wanting to run but these dont rub. Its close but thats all you need.
Old Jan 19, 2005 | 10:02 AM
BAJA_SD's Avatar
BAJA_SD
Who's leveling kit did you use, and what does it consist of?
Old Jan 19, 2005 | 10:10 AM
Hjudge49's Avatar
Hjudge49
I am ordering Toyo's. We just put a set on my son's F150 and they ride and look good. BAJA, I got the Daypro (I think or Daystar) kit. It consisted of a poly block for the top of the front springs, replacing the stock block, longer heavier and better front shocks and a 1" plated rear spring block. Very easy to install, took less than 1 hour. The only adjustment was to center the steering wheel after the install.
Old Jan 19, 2005 | 10:21 AM
BAJA_SD's Avatar
BAJA_SD
Did you check the Caster before and/or after the lift? The lift should reduce the Caster but perhaps not significantly. Can you tell any difference in the steering characteristics of the truck?
Old Jan 19, 2005 | 10:43 AM
wolffee's Avatar
wolffee
I am running the procomp 2.5in full leaf spring kit. Replacing the leafs upfront and new shocks U bolts the hole 9yards. rides great and makes the truck look good with that 4 inch rear block that my 350 SRW came with. Good Luck
Ryan
Old Jan 19, 2005 | 11:54 AM
Hjudge49's Avatar
Hjudge49
No difference at all. Drives like a dream
