today while driving my '80 F-150 4x4 w/ 400 cui engine, the engine just cut out on me while i was driving 35 mph. i then coasted over to the side of the road, got out and check all my electrical connections (battery, alternator, ignition coil) and all seemed to be connected. i got back in and started the engine right up, put it in reverse and put it into drive and drove for about 5 seconds then it cut out again. i then checked again, jiggled all the connections, got back in and started up right up again and drove off, this time with no problems. i drove it into an empty parking lot to make sure it was working fine and drove it around for about 10-15 minutes with no problems.
i am at work now and was wondering what you guys think the problem is and what i can do to check or fix this problems before my trip back home. thanks for your time.
that could be the problem
i drove it all the way back home today without any problems.
the one problem i have been having is when starting the engine cold, i turn the key to start it and the starter starts to crank, but i have to slowly turn the key back towards me before it ignites up.
i believe my module is about a year old so maybe i'll take it in to get a new one.
thanks for your reply
I have experienced this same problem numerous times, the ignition module is the cause of the hard starts and stalling. I had to replace my ignition module about every 6 months, after a year and a half of this, I researched more and was told that Ford uses a resistor type wire to provide power to the module. Since i had rewired all of my engine compartment I had removed the resistor wire, therefor, i was sending to much power to the module causing it to burn up over time. I remedied this by replaceing the ignition module with a Mallory promaster coil and breakerless magnetic advance distributor. The coil comes with its own ballast to drop the voltage to what it needs. Also after this replacement, i got better gas mileage and was able to run the engine at higher rpms without the ignition breaking up( another problem i was experiencing with the stock module).
