Another problem
Old Aug 30, 2002 | 11:56 PM
rratliff23's Avatar
rratliff23
Another problem
Old Sep 3, 2002 | 11:27 PM
Fordmanwithacause's Avatar
Fordmanwithacause
Another problem
Hello,
I have an 86 f150 with a efi 302. I hear a ticking comming from the engine compartment. So I listen and it is comming from the injectors one or more i dont know. Are they supposed to tick. Any help is greatly appreciated.
Thank you in advance.
Old Sep 4, 2002 | 09:18 AM
coolcatF150's Avatar
coolcatF150
Another problem
Fuel injectors usually have a light tick to them, yet hardly noticable. The ticking you may hear can be a stuck lifter or a tapping pushrod or rocker arm. They are all located near the fuel injectors.
Old Sep 4, 2002 | 05:19 PM
Fordmanwithacause
Another problem
I used a hollow pipe to check the valve covers and its not comming from there.i placed it on the injector and thats were its comming from. I dont know if it could be a lifter but i know its not a rocker or pushrod.
thanks for the advice cool cat.
does anyone else know if a bad injector could cause this ticking.
thank you in advance.
