Sponsored by: Kumho
Touchy Brakes?
Old Jan 18, 2005 | 06:44 PM
JoeKramer's Avatar
JoeKramer
Question Touchy Brakes?
Why would the power brakes on my '89 F150 5.0 AT 4x4 be really really touchy why I first drive the truck? Is it anything I sould be worried about?
Thanks guys!
Old Jan 18, 2005 | 08:50 PM
Tailhunter18's Avatar
Tailhunter18
???Maybe try bleeding um???
Old Jan 18, 2005 | 10:00 PM
JoeKramer's Avatar
JoeKramer
Um...
If there was air in the line then why would they chill out after a minute? I'm not a brake guy. LOL
Old Jan 18, 2005 | 10:17 PM
93truck's Avatar
93truck
i experienced this problem when i park my truck outside,i think it may have something to do with moisture slightly rusting the rotor surface, my wifes escape also does this. it may also be from your parking brake (if you use it) not releasing fully till the truck rolls.
Old Jan 19, 2005 | 01:21 AM
Dragrazor's Avatar
Dragrazor
Your rear drum shoes might be adjusted to close to the drum?! Mine started doing this after I adjusted the rear shoes!
Old Jan 19, 2005 | 01:35 AM
JoeKramer's Avatar
JoeKramer
It isn't the back brakes. I come to a stop and the truck acts like I slamed on the brakes. If it was the rear brakes then the back tires would lock up in gravel and they don't do that.
Old Jan 19, 2005 | 02:50 AM
Beast12's Avatar
Beast12
This is a very common occurence with rear drums. Iti s PROBABLY just a little moisture on your rear shoes and then when you put your foot on the brakes then they grab really good. After driving for a bit they dry up and then it is gone...until tomorrow.
Another thing to check (if you have the time and want to make sure) is your rear wheel cylinders. If they leak and you get brake fluid on your back shoes then they are contaminated and you will need to replace the shoes as well as the wheel cylinder.
BUT, it is PROBABLY the first thing I said.
-Matt
Old Jan 19, 2005 | 11:35 AM
Dragrazor's Avatar
Dragrazor
YEP, I agree!
Old Mar 20, 2008 | 04:48 AM
troc99's Avatar
troc99
I know this an old posting,but what did you find the problem to be with your breaks?
CLARK3234
May 16, 2014 03:03 PM
vloney
6.7L Power Stroke Diesel
50
Sep 16, 2013 11:09 PM
PlatinumKanikas
1997 - 2003 F150
Jul 26, 2011 06:39 PM
Bayer-Z28
General Automotive Discussion
Mar 14, 2010 07:38 AM
scootin
1978 - 1996 Big Bronco
Feb 3, 2004 10:29 PM
