need help no power
Old Jan 18, 2005 | 05:21 PM
jimbo96's Avatar
jimbo96
Cool need help no power
i need help i have no power. every time i hit the gas it falls on its face and spits and spuders. anyone that could tell me what it could be i could use the help.
Old Jan 18, 2005 | 05:31 PM
Tailhunter18's Avatar
Tailhunter18
Well....it could be a number of things......What year truck you got??? Does it idle rough or when you step on the gas does it shake....Could be plugs, wires, cadillidic converter, accellerator pump, fuel filter, timing....
Old Jan 18, 2005 | 06:09 PM
jimbo96's Avatar
jimbo96
it is a 95 i got a fuel filter tonight and going to see it that will work
thanks jim
Old Jan 18, 2005 | 06:57 PM
Tailhunter18
good luck!!!
Old Apr 8, 2008 | 12:42 PM
ky_ace's Avatar
ky_ace
I'm having a similar issue with my 94 4x4 351. My truck idles just fine but falls on its face upon accel. I had the IAC and Fuel Press. Reg. go bad last week and replaced them both. while under the hood i also replaced the plugs. Looks like i'll be replacing the cap and rotor tonight becuase when i pulled them at lunch there was a bit of moisture in them along with the fuel filter. I too will report on my findings, and move on to the rest of the never ending list if not!! Oh.. and i have no CE light on either.. just trippin' and bustin' it's nose just off idle, and between gears.
Old Apr 8, 2008 | 01:22 PM
Conanski's Avatar
Conanski
That could be a vacuum leak, look for broken vacuum lines or a rusted out vacuum resovoir. A sticking EGR could also cause similar problems.
bsneed
Sep 18, 2010 06:54 PM
williamm3267
May 23, 2010 05:59 PM
dale4133
May 16, 2010 11:58 AM
dyoung14
Apr 25, 2008 08:28 PM
