alignment specs
Old Jan 18, 2005 | 05:14 PM
msanders35's Avatar
msanders35
alignment specs
Can someone please tell me what the alightment specs are for my 1964 F100?
Mostly I need the angle that my wheels should be set to: and should they be set like this / \ or like this \ /.
Thanks
Old Jan 18, 2005 | 05:56 PM
daveg66's Avatar
daveg66
Is that a top view or front view? On my 66, the toe in is set 1/8" angled in at the front. front
rear
Not sure about camber / caster, only checked it by eyeball.
Dave
Old Jan 18, 2005 | 06:00 PM
msanders35's Avatar
msanders35
Great thats what I needed. Thanks
Old Jan 19, 2005 | 01:33 PM
cobraguy's Avatar
cobraguy
You should have 1/16"-1/8" toe in(front of tires pointing towards each other). Other angles are not normally adjustable and shouldn't be worried about unless something went horribly wrong. Once the toe is set the steering wheel may not be straight when driving. There is an adjusting sleeve on the drag link that will need some twisting. If you need I can give you some tips for that adjustment.Rich.
