Steering column to use?
Old Jan 18, 2005 | 03:24 PM
sixshootingexp's Avatar
sixshootingexp
Smile Steering column to use?
I have a 79 f-150 2wheel drive automatic with bad tilt column.
Does anyone know what years and style are interchangeable with this, possible to use 4x4?
Old Jan 18, 2005 | 06:58 PM
modrisco's Avatar
modrisco
Hi, you can use a tilt column from a 78-79 truck. To use the one from a 4x4 just remove the shaft extension and put your flange to bolt up to the rag joint. 73-77 are very similar and will work but don`t look exactly the same.
Mitch
Old Jan 18, 2005 | 10:42 PM
Mil1ion's Avatar
Mil1ion
The only difference between 2x4 & 4x4 steering column to box is between the end of the column to the box.The column is the same.
The 2x4 has a mounting flange to the rag joint & the 4x4 has a shaft with U-joints in it.
Old Feb 5, 2005 | 05:01 PM
GeneStoner's Avatar
GeneStoner
Can you install a U-joint at the base of a 2wd column for use in a 4wd truck? Or, otherwise modify the 2wd column to work in that 4wd application?
Old Feb 5, 2005 | 05:50 PM
Mil1ion's Avatar
Mil1ion
Yes completely inter-changeable.
Old Feb 5, 2005 | 08:08 PM
oldhalftons's Avatar
oldhalftons
late columns have the rag joint flange welded to the steering shaft.
so you need a intermediate shaft with a rag joint. I know borgeson makes one if you can't
find an original one
Old Feb 6, 2005 | 03:52 AM
HD F150 SC's Avatar
HD F150 SC
Mil1ion, Can you take a rag joint off the column of a '76 F100 2WD AT and convert it to u-joint? Would I need the 4x4 column? I need to replace my butchered column anyway.
Old Feb 6, 2005 | 12:37 PM
oldhalftons
a 76 2wd column, most likely has a splined shaft and a bolt-on ragjoint coupler
