Tranny overhaul problem
Old Sep 7, 2002 | 10:25 PM
gingerbreadmaniac's Avatar
gingerbreadmaniac
Old Sep 8, 2002 | 01:33 PM
kurtlogan's Avatar
kurtlogan
I am having trouble removing the rear main bearing from the output shaft on my 83 F150 manual 4 speed OD transmission. It is frozen to the shaft. It is supposed to slide off. Any Ideas?
Old Sep 9, 2002 | 10:22 PM
otto's Avatar
otto
if its a ball bearing you might shatter the outside race of it with a hammer and all the ***** will fall out and you could cut the inner race with a die grinder and zip wheel (you'll need abrasives on roller bearing race hacksaw wont touch it) if its just a sleeve like copper or babbit with steel back you could just saw it off
Watch your eyes if you shatter a ball bearing they shatter something fierce
