Noisy 7.3
Old Jan 18, 2005 | 09:42 AM
Bar L's Avatar
Bar L
Noisy 7.3
I just got a 2000 F350 XLT Powerstroke, this is my 3rd powerstroke and my dad has had 4, his newest is a 2000 model. My question is why is it so noisy in the cab? The engine noise is obnoxious does anyone have any suggestions. My dads 2000 is the same way.
Old Jan 18, 2005 | 10:50 AM
Max1775's Avatar
Max1775
Were the other trucks newer or older? My friends 99' is quieter than my 97', and the 04 is even quieter. Maybe they scimped on insulation in that year? Don't have a 00' to compare them with though. You can buy insulation pads to put in the floorboard, behind the dash, in the doors, etc... They sell stuff like that at audio shops.
Max
Old Jan 18, 2005 | 11:13 AM
Bar L's Avatar
Bar L
The other trucks were older. Outside the engine does sound quieter but in the cab it is noisy. All the trucks are manual trannys, maybe the 6 speed is a noisy tranny. I am going to to insulate the firewall and around where the stick comes through the floor. I didnt know if anyone had some tips that might help. I wondered if it may have something to do with the way the tranny was mounted or needed some rubber bushings.
Old Jan 18, 2005 | 11:25 AM
Max1775's Avatar
Max1775
Does the truck have an aftermarket downpipe? I had a problem with mine touching the firewall and had to change the worn out OEM cab bushings with polyurethane and the problem disappeared.
Max
Old Jan 18, 2005 | 11:46 AM
Bar L's Avatar
Bar L
Factory exhaust, although I am getting 4" put on. I will take a look at the cab mounts. It isnt too bad until about 2300 rpms and then it get loud in the cab. Im afraid it might be worse with the 4" exhaust. I was also told it was probably resonence(sp).
Old Jan 18, 2005 | 01:01 PM
doc526's Avatar
doc526
I have a 2000 F250 7.3 and it does not seem to be too niosy. My dad has an 03 F350 w/ the 6.0 and it does not seem to be any louder in the cab (in my opinion anyway) than his.
Old Jan 18, 2005 | 04:13 PM
mybigredford's Avatar
mybigredford
my 02 is pretty quiet i the cab, until the cold snap last week and then it sounded like a jet engine inside, but it is quiet again, thank goodness.
Old Jan 18, 2005 | 06:10 PM
lancer's Avatar
lancer
I have a 99 and it was good and quiet when i got it. But now that i have stacks and the kwik filter she alot louder now. I'm used to it now. My dad recently bought a 2000 sd diesel. Now when i get in his its so quiet i can't believe it. I like my mods though so i won't change a thing!! I might try that suond proofing in the spring but who knows. I want my chip first!!
young ford man
May 21, 2015 05:31 PM
2000+1998
Aug 24, 2013 12:27 PM
fastblkford
23
Feb 3, 2012 11:29 AM
meierw1
Jul 23, 2011 06:25 PM
show dad
23
Jun 7, 2007 02:45 PM
