Sponsored by: Real Truck
Computer changes for gear swaps?
Old Jan 17, 2005 | 09:42 PM
mizzitch's Avatar
mizzitch
Does changing the gear ratio from 3.73 to 4.10 on a V-10 automatic SD require any reflashing of the computer, or does the trans just learn to shift with the new setup?
Old Jan 17, 2005 | 11:54 PM
SMiller's Avatar
SMiller
No the computer doesn't learn to fix the problem. I would run with it, the shifts are going to be a little higher all around, you might be bumping the fuel shut-off on WOT shifts though, see how it drives, if it hits the rev-limiter then you need to fix the problem, other then that I would leave it.
