General Automotive Discussion
Wheel Adapters
Old Jan 17, 2005 | 04:33 PM
sierraben's Avatar
sierraben
Wheel Adapters
Anyone use wheel adapters and what are the pros and cons of using them ? Are they safe . I know that the new ones are made from 6061 aluminum alloy . I'm thinking of purchasing some .
Old Jan 17, 2005 | 10:30 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
What are you planning on doing? As in, are you changing bolt patterns, or using them for spacing?
Old Jan 17, 2005 | 10:52 PM
sierraben's Avatar
sierraben
Hey bigrigfixer, I'm not going to use them as spacers, but to change bolt patterns. I need to mount some old wheels so I can move my truck around in the garage. Also I do have two sets of wheels with different bolt patterns. And room is at a premium in my garage.
Old Jan 17, 2005 | 10:58 PM
bigrigfixer
The Pacifier
Lots of people use them reliably without problems. You should be okay. If you were going to use them as spacers, well, there is a maximum. I'm not sure what the maximum is though, and that's not what you're doing, so never mind.
Old Jan 18, 2005 | 12:37 AM
sierraben's Avatar
sierraben
Hey bigrigfixer, thanks for the input . The major drawback to these adapters is the cost . Because of my particular hub to wheel size (5x4.5 hub to 5x5.5 wheel), it's going to cost me about $175.00. Dang . Oh well. Again, thanks for the input .
Old Jan 18, 2005 | 09:37 AM
5_labsownus's Avatar
5_labsownus
We used them on trailers years ago. If you are going to drive with them use a torque wrench and the bolts and check them daily. we had them come loose abot every 200 miles when torqued and we had one come off after 50 miles!
I think buying rims is a better way to go!
Old Jan 18, 2005 | 12:54 PM
fellro86's Avatar
fellro86
those size rims are very easy to come by, for way less than the adapters, I would think it easier and cheaper to buy some steelies from a salvage yard...
Old Jan 18, 2005 | 09:59 PM
sierraben's Avatar
sierraben
I've read that those adapters do come loose . I used to have the old style cast wheel adapters, but never had one ever come loose or come off on me. Like I said before, space is at a premium. Stupid me . I just remembered that I do have a set of original Torq Thrust D's that fit my truck . I could put on a set of may-pops. Then I could roll the truck around in my garage. Thanks guys for your input; much appreciated.
