Service Engine Soon
Old Jan 17, 2005 | 01:57 PM
99questions's Avatar
99questions
Question Service Engine Soon
I have had my service engine soon light on now for about 2 weeks. According to my manual, it says it may have some thing to do with the fuel. Well I have gone through 2 tanks of gas and made sure my fuel cap was on securely. Any other ideas?
Old Jan 17, 2005 | 06:42 PM
the4by4freek's Avatar
the4by4freek
Service engine soon light is the same thing as check engine light or CEL. Your ECM (electronic control module) has stored a fault code for your truck. My best advice is to take it to Auto Zone and have them pull the code and tell you what is wrong. Once you find out what code it is you could search this board for your fix or you could just replace the part that is bad. This board is a valuable tool for fixing your Expy. Use the search feature and you will find just about every answer to almost every question. Hope this helps!
