Sponsored by: Auxito
Engine knock
Old Jan 17, 2005 | 09:20 AM
loy510340's Avatar
loy510340
Question Engine knock
My starter had gotton loose so i tightened it up and changed my oil. When i checked to see if the starter was tight enough the 1997 4.2 had a terrible knock and blew a little antifreeze from my exhaust. I read the front engine cover gasket and the lower intake gasket often fail causing hydrolock. Is the recall a factory recall or am i just screwed.
Old Jan 17, 2005 | 09:30 AM
loy510340's Avatar
loy510340
Whos there
Old Jan 17, 2005 | 10:43 AM
PaulC's Avatar
PaulC
Well, no factory recall. Check out the 4.2 engine section on this website. You'll find a lot of discussion on this matter there.
