Has anyone had experience with swapping a later steering column what has the headlight dimmer on the column with the directional into an '86 truck? It's been years since I had a foot switch and if it's not too difficult, it'd be worth the effort to me.
Thanks
you would a 92 or newer cloumn, and they are shaped totaly different not to mention the all diferent wiring harness connectors, also the column mounted dip switch is harder to replace, more expensive to replace, more prone to fail than what you have now imho
