Sponsored by: Real Truck
anybody have this??????????
Old Jan 16, 2005 | 06:09 PM
74fordhighboy's Avatar
74fordhighboy
I just bought a used fabtech 3.5 inch front lift kit and i do not see a track bar bracket and i went to fabtechs web site and downloaded the instalation guide and it did not say anything about a differant track bar bracket ???????????????????????????? Can i use my stock one or is it going to push the front end over?
Old Jan 16, 2005 | 06:42 PM
DCSpecial's Avatar
DCSpecial
All that comes in the kit is the 3.5" hangers and brackets to relocate the stock shackles.....optional replacement front crossmember.
No trac bar bracket or pitman arm is included.
If it was my truck I'd install a adjustable trac bar. If you do a drop trac bar bracket you'll want to add a matching drop pitman arm to keep the steering geometry the same.
Old Jan 16, 2005 | 07:15 PM
74fordhighboy
so is it going to do any thing if i dont do either one?
Old Jan 16, 2005 | 07:20 PM
DCSpecial's Avatar
DCSpecial
It may slightly cause your axle to be off center and pull down on the driver's side.
Old Jan 16, 2005 | 07:22 PM
74fordhighboy
where can i get an ajustable trac bar?
Old Jan 16, 2005 | 07:26 PM
DCSpecial's Avatar
DCSpecial
Anyone that sells Donahoe Racing and/or Fabtech can get you a adjustable trac bar.
Or, if you are good at fabricating you could modify your stocker for the additional length.
Old Jan 16, 2005 | 07:29 PM
74fordhighboy
i can fabricate but how much do i need to add?
Old Jan 16, 2005 | 07:31 PM
DCSpecial's Avatar
DCSpecial
You'd have to wait until the 3.5" Fabtech is installed, make sure the front axle is centered, and then measure.
Old Jan 16, 2005 | 07:42 PM
74fordhighboy
so is that just soft steel and i could cut it and just put a piece of pipe in between and weld it?
Old Jan 16, 2005 | 07:43 PM
74fordhighboy
what about my sway bar links?
Old Jan 16, 2005 | 07:47 PM
DCSpecial's Avatar
DCSpecial
I would cut it, sleeve it with a piece of tubing that will go from end to end, drill some holes through the outer tubing, weld the ends and weld up the holes.
Old Jan 16, 2005 | 07:50 PM
DCSpecial's Avatar
DCSpecial
If the sway bar is pulled up, you can flip the upper sway bar link mounts from inside the frame rail to below the frame rail. Two bolts hold the upper sway bar link mounts to the frame rail plus the upper sway bar link bolt goes through the frame as well. So three bolts per side, flip the mount, reinstall the bolts.
That's what was done per the instructions when we installed my 4" Rancho.
Old Jan 16, 2005 | 07:57 PM
74fordhighboy
i think that this site is more helpful than the actuall supplier thanks alot
Old Jan 16, 2005 | 08:07 PM
DCSpecial's Avatar
DCSpecial
Let us know how it turns out.
