External slave cylinder bleeding?
Old Jan 16, 2005 | 03:57 PM
grandjunktion's Avatar
grandjunktion
Hi, I have a 1985 Bronco 4 speed manual transmission. The clutch feels spongy like its not fully engaging and it is very difficult to shift into all gears with the engine running. I thought maybe air got trapped in the slave cylinder line and thought id bleed the system but there doesnt seem to be a bleed valve screw. I looked it up in my Haynes manual and the external slave cylinders aren't able to be bled. Is there any thing I can do aside from replacing the whole unit? Is there something else that could be causing the problem? Please Help.
