fuel selector valve
Old Jan 16, 2005 | 12:27 PM
RhinoVirus's Avatar
RhinoVirus
fuel selector valve
I need to replace a cracking rubber fuel line that has been spliced into the metal supply line coming off the selector valve that runs along the frame rail.
Anybody know if I can do this without crimping the rubber line.( will fuel flow out of the selector valve when there is no power)?
Old Jan 16, 2005 | 06:07 PM
Dave Sponaugle's Avatar
Dave Sponaugle
If the tanks are all the way full or the back is higher than the front it will run out.
Not a lot, but enough to make you mad as it runs down your arm since you are laying under it.
Old Jan 16, 2005 | 11:35 PM
RhinoVirus's Avatar
RhinoVirus
Thanks dave
