Aerostar Ford Aerostar
Tire Carrier?
Old Jan 16, 2005 | 09:23 AM
Aftrmidnite's Avatar
Aftrmidnite
Tire Carrier?
I'm going to put a full size spare tire on my Aerostar. I was looking at the cable and it has a little rust on the end. I'd like to replace it. Can I use larger diameter cable? I noticed there's a no rub ferral on the cable were it goes thru the spare tire hub bracket. What can I do about replacing this ferral? I have the cable crimping tool.
Old Jan 16, 2005 | 11:14 AM
eehoepp's Avatar
eehoepp
Check with your local dealer's service department. My 95 Aerostar was recalled to have the spare tire carrier replaced. I can't remember if it was for cable breaks due to rust or winch seizing, but mine worked fine when they pulled it out and replaced it.
Your van may also be on the recall list. If not, there is obviously an "improved" version of the carrier available from Ford.
Cheers,
Eric
Old Jan 16, 2005 | 12:06 PM
Aftrmidnite
Mines a "late build" 94, it would be great to get a new spare tire carrier.
Old Jan 17, 2005 | 11:33 AM
Aftrmidnite
I checked; the recall was only for 95 short body Aerostars, there was nothing wrong with the spare tire carrier mechanism, it just let the spare tire rub against the brake lines. So I need to find out if I can replace the cable, unless you can tell me something different about the recall.
Old Jan 17, 2005 | 05:52 PM
CdnSoldier's Avatar
CdnSoldier
Aftrmidnite
It is not just for shorties, it is for ALL Aerostars. Mine is a 94 Ext XLT. They only replace the cable.
Old Jan 17, 2005 | 06:03 PM
rob1994AerostarAWD's Avatar
rob1994AerostarAWD
I had mine in for the recall but the cable was ok. The rest of the carrier was rusted. I have since removed the carrier (just a few bolts) and grinded and repainted with gloss black rust paint. Looks great One of these days I have to put it back on. Spare is in the back for now.
