96 still won't start
Old Jan 16, 2005 | 07:32 AM
Gasurffish's Avatar
Gasurffish
Before I take it to a dealer will try again for a possible answer. Engine starts and runs fine when cold when trying to restart it will turn over, there is fire to the plugs but will not run. When pulling plugs they are very wet like they are flooded even after a very little turnover. Can they be getting to much fuel or not enough air?? I have replaced the ignition module plugs , wires, ignition coil, dist cap pip sensor in dist and rotor no change. Need some suggestions.
