changing headlight bulb?
Old Jan 15, 2005 | 08:09 PM
modru2004's Avatar
modru2004
ok i took the thing out put in the new one. but the little grey screw cap or what ever its called, when i get it to slide back over, i can't get it to turn to lock it in place again. it slides over but won't turn once its there.
Old Jan 15, 2005 | 08:28 PM
tex94F250's Avatar
tex94F250
Make sure you have the correct tabs in the correct position. When inserted twist clockwise till it locks. This will only work if the correct tabs are inserted into the slot openings.
Luck, Tex
