conflicts?
Old Sep 26, 2002 | 06:38 PM
crazy4Fords's Avatar
crazy4Fords
conflicts?
hello all just want to sepread this ands see what i can do for my truck before i make any mistake or get some challege , i m planing to restore my 81'f250 4x4 i plan to install 429 engine replacing the 351M also will be adding 6 inches suspension lift .. so i m making sure i wont get any problem or see any so any suggestion before i do or ahead to watch out for something ? thanks all
Old Sep 26, 2002 | 07:29 PM
Mil1ion's Avatar
Mil1ion
conflicts?
WElcome to FTE!
I would suggest a search for Engine swap in this forum.
Go to the search function on the main page of the message boards.
Type in *460 swap* by Subject and *all posts*> Pick the 80-86 forum and Up they come
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Sep 27, 2002 | 01:41 AM
Superdave's Avatar
Superdave
conflicts?
crazy4Fords, My son and I did this swap this past spring. Well from a 400 to a 460 anyway. Should be the same thing. We got the factory engine perches that mount to the frame. Then there are factory plates that fasten to the block its self, then your rubber mounts sandwich between these. I got all the stuff for an 83 F-250 4x4 which is the first year they offered the 460 in our body style. Or you could use the aftermarket adapter engine mounts. We used all the accessory brackets and steering pump from the donor vehicle which was a 79 E-250 van. I had my local NAPA make up a custom high pressure steering hose for the steering pump swap. Rear sump oil pan and hardware. You will need truck or van exhaust manifolds also, unless you are using headers. Offset oil filter adapter or remote filter mount, alter your factory throttle cable bracket and your in business.
Old Sep 27, 2002 | 01:47 AM
nopatno's Avatar
nopatno
Post conflicts?
