Headliner
Old Jan 14, 2005 | 09:56 PM
opus's Avatar
opus
Headliner
I took the headliner out of my '63 last summer. I would like to put it in but the sweating of the roof is unreal, with the drastic weather changes we have. What do you suggest to keep from ruining the headliner from all the sweating?
Old Jan 15, 2005 | 02:10 AM
camperspecial65's Avatar
camperspecial65
originally, some trucks had insulation pad....jute stuff essentially....glued to roof of truck...I would do that but with reflective type barrier for heat/cold and moisture. i would put some at rear overhang area on inside..none there originally....
Hope this gives ya ideas....just dont cover screw holes on edges and one in center.....
-cs65
Old Jan 15, 2005 | 05:28 AM
jowilker's Avatar
jowilker
Hi Pete, One of the reasons that you see the moisture is because the interior climate is exposed to the metal and not the cardboard, and reacts differently. Adding insulation and the headliner will cause that to change.
John
Old Jan 15, 2005 | 09:52 AM
opus's Avatar
opus
That is what I figured. What wouldone suggest for insulation....that will hold up for some years?
Old Jan 15, 2005 | 04:22 PM
carras's Avatar
carras
I'm thinking of trying exterior house sheathing. the stuff that made of hard form with a foil cover. I think it comes in various thicknesses
Old Jan 15, 2005 | 05:49 PM
bertha66's Avatar
bertha66
I had a sprayed-in bed liner put in on my 66 and had the inside of the cab shot at the same time, work good as insulation and sound deading,
Old Jan 15, 2005 | 07:29 PM
Customcab's Avatar
Customcab
I installed (3 in 1) insulation; I place the insulation portion against the roof & the aluminum side downwards; also installed it under the floor cover; Its called 3in1 because it insulate against heat,cold & noise. My roof section (insulation) is in two section splitting the center cross brace. Its a great product can be found in almost any parts catalog to include J.c Whitney.
Hope this helps..
C.C.
Old Jan 15, 2005 | 08:06 PM
opus's Avatar
opus
Would this be what you mean?
http://www.jcwhitney.com/autoparts/P.../p-394/c-10101
Old Jan 16, 2005 | 07:55 AM
Customcab's Avatar
Customcab
Opus;
The actual product from J.c Whitney I purchase was item # ZX250705N for now $19.95 and their offering free shipping today; Its was regular price when I bought it last year or so. Like I said earlier I also purchase two rolls and did my floor board as well.
Hope this helps out. It was alittle tight putting the headliner back in with insulation first, just trim insluation to lay in the front lip of your roof edge and sides; also I didn't cover the center brace with insluation as well.
Mitch
Old Jan 16, 2005 | 09:39 AM
opus's Avatar
opus
Mitch,
Cool...thats what I will get. Did you stick it to the roof somehow? You probably just bought some tape and taped it?
Broomfieldbum
Jun 27, 2011 02:10 AM
phubble
17
Mar 13, 2010 08:05 PM
slmd350
Jul 5, 2006 03:16 PM
brider
38
Jul 12, 2005 01:18 PM
ExpoBoi99
Mar 28, 2004 03:39 PM
