please help
Old Jan 14, 2005 | 07:44 PM
celticbear's Avatar
celticbear
Cool please help
was wondering if anybody out there could tell me what the code 98 hard fault FMEM engaged is as far as the part
Old Jan 15, 2005 | 07:00 AM
trike1946's Avatar
trike1946
This is from ann "actron" book.
98
A system problem is present causing the Electronic Control Assembly (ECA) to operate in Failure Management and Effects Mode (FMEM).
or,
Right side Exhaust Gas Oxygen (EGO) sensor-signal voltage indicates "lean" during "rich" air/fuel conditions.
or,
Electronic Pressure Control (EPC) solenoid circuit failure.
Never had the problem so I can't tell you any more than that. Good luck with it. Maybe someone else will have more info.
Old Jan 15, 2005 | 07:09 AM
trike1946's Avatar
trike1946
I found out the EPC is part of the transmission. Seems to have to do with shifting pressure.
By the way - Welcome to FTE.
Old Jan 15, 2005 | 01:55 PM
celticbear's Avatar
celticbear
not having trouble with trannie shifts fine the other code is the throttle position sensor which is code 63 does one have to do with the other ? so does this mean that fmem is telling me that the tps is bad thanks for your in put
1988 e-150 351m
Old Jan 15, 2005 | 03:52 PM
trike1946's Avatar
trike1946
With my very limited knowledge of this I can tell you that the tps has to do with the trans. My plug came loose and I had trans problems. Maybe yours is bad or dirty contacts. There is propably a way to test it in the manual. Since I am not an electrical guru, I really don't want to give you any bad info, and all these electrical gremlins usually get the best of me. If you don't get more good info here, you might try the electrical forum. Sorry I can't be of more help. Good luck with it.
