I have 2001 4X4 with a 4.0 automatic, and when I accelerate up to highway speed the motor has a pinging noise until I get up to speed. I haven't tried any fuel additives or anything like that. I have noticed a loss in gas milege. from 21.5 miles per gallon to 20 over the last 2 years.
I've heard of a case or two where the SOHC upper intake gaskets were leaking, allowing unmetered air in and causing a lean condition. Running lean and pinging go hand-in-hand.
A dirty MAF sensor is fair game. Also, I have to wonder if, given the problem description, the infamous timing chain issue is making itself known. Does the ping (noise) occur under other conditons, such as when the engine is warm and you step on it hard while going perhaps uphill, say 35MPH, and around 1300-1800rpm?
It does not matter if the engine is cold or warm the pinging noise is the same, The pinging occurs only when I accelerate up to speed. Once I am up to speed and I let up on the gas pedle the ping goes away. When passing another vehicle I step on it hard it pings only for the first couple seconds. Where is the MAF sensor located ? If the Intake gaskets were leaking would it ping all the time or notice it more when the engine was cold ?
the maf sensor is right next to the airbox. it is black and flat and is held on by two screws, when you take the maf out it has two small filiments like a light bulb so be careful not to damage them. the best way to check the intake gasket is to hook up a vacuum guage to the vacuum tree on the intake.
This was the problem with my truck for six or seven years. I even took it to the dealer and they just ignored me about the problem. Terrible acceleration also, besides the loud pinging.
A good cleaning and it runs great. Like el conquistador said above, be careful. Also, you must disconnect your negative battery terminal while cleaning it for about 10 minutes to reset the sensors or whatever.
I cleaned mine with some brake/carburator cleaner spray then with some rubbing alcohol. Runs almost brand new now.
Thanks, SmokyMtnz that was my next Question ( what to clean the MAF with ) I will give it a try as soon as the weather breaks. we had no electric for 4 days then got flooded out.
