u joints 4x4
Old Jan 14, 2005 | 05:29 PM
sourpuss's Avatar
sourpuss
u joints 4x4
i have a 89 4x4 and i need to change the ujoints in the front wheeels, i have taken the nuts off the ball joints so whats next does the whole spindle come off and if so how
Old Jan 14, 2005 | 07:16 PM
magna19's Avatar
magna19
you dont have to take the ball joints off,pull the hub,rotor,and then the 6 bolts that hold the spindle to the knuckle.then pull the spindle off,pull the shaft out,done deal,the right side is harder due to the slip joint,mark it,and take the slip joint apart.
Old Jan 14, 2005 | 07:37 PM
sourpuss's Avatar
sourpuss
thanks for ur help magna19
Old Jan 16, 2005 | 07:24 PM
51frrdtrk's Avatar
51frrdtrk
I just compleated this job on my 94, F250 and the hardest part was getting the spindle off. I purchased a tool at the local auto store that screws onto the spindle and uses a slide hammer to remove. I still had to use a little torch heat on the inside to break them loose.
When putting back togeather with a new inner dust seal be sure to install the plastic seal. i forgot this and had to remove one wheel and install it.
