No Heat
Old Jan 14, 2005 | 11:48 AM
queeniesma's Avatar
queeniesma
No Heat
Help! I have a 91 Explorer.On Sunday I had a leak at the waterpump area, and loss of heat. My husband put in a new waterpump,now I have no leaks. But the heat and temp gauge would fluctuate. The higher the temp, the colder the air. Replaced the t-stat, no change. My husband thought there might be air in there, so we keep putting in coolant and water while running.Today the temp gauge reads low, and I had heat for awhile, now nothing. Alot of the coolant and water is going to the overflow tank, then spewing over.Any ideas, me and the kids are freezing our tails off!!!!
Old Jan 14, 2005 | 05:37 PM
yendor's Avatar
yendor
Take top heater hose off of heater core hold it up in the air high enough to fill from there.Put jug under outlet of heater core to hold coolant that will come out of there,pour untill you know it is full take apart real quick and put back togeather. Then try for heat.
