Power problem
Old Jan 13, 2005 | 10:07 PM
snowman13's Avatar
snowman13
Truck won't Turn over
Hi, 1st timer,I have an 88 F-150 4x4 and I had to get a jump tonight, when a turned over the ignition there was a quick flicker of light than no power.Once I connected the jumper cables it started. When I got home and turned it off and tried to start it up again no luck. I thought it might be my battery but the charger says its good. I'm woundering if its a connection to the battery itself. P.S. when I drove home there was no spiking or charging problem. Any help would be great.Thanks
Old Jan 14, 2005 | 04:32 PM
Franklin2's Avatar
Franklin2
Yes. Clean the battery cables, and the cables on the starter relay. Also check and clean the other end of the battery ground cable that connects to the engine block.
Old Jan 14, 2005 | 08:50 PM
snowman13's Avatar
snowman13
Thanks for the help and it wasn't getting any power because of the corrosion on the postive side of the cable attached to the battery.
