Mulitiple problems
Old Jan 13, 2005 | 09:22 PM
ACE81's Avatar
ACE81
Mulitiple problems
Going down the road the other day, my 1995 truck died when I turned the corner. Unable to get it cranked. Towed it to a shop, found out it was the igition module. Plus I have an oil leak from the plug and a leak from the radiator. Gonna cost me $332.00 for the igition module and a distibutor. Got any ideas on the other problems.
Thanks,
David
Old Jan 13, 2005 | 10:41 PM
frederic's Avatar
frederic
If the oil plug leaks you replace the gasket underneath it for about a dollar. Its a simple rubber or urethane washer, essentially. Or, spend $5 and by a whole plug with the right gasket and nice clean threads.
Radiator leak, well, depends where on the radiator its leaking form. If its from the plastic tanks, you can replace them (or the whole radiator), or repair it yourself using a plastic welding kit (essentially, a soldering iron with a funky tip on the end).
If its not the tanks, but the core itself, that too can be fixed by a compentant radiator shop.
BTW, if your initial problem was the ignition module, why did they replace the entire distributor? Was there something wrong with it? 92 and up only have one moving part - the shaft - and the rest of it is a cup with slots and a magnetic sensor, neither of which go bad generally speaking.
Old Jan 13, 2005 | 10:43 PM
pfogle's Avatar
pfogle
May I ask why they are replacing the distributor? the ICM is a seperate part (about $35 and you can replace it yourself.) that is on the inner fender well, or firewall.....
Old Jan 15, 2005 | 12:41 AM
ACE81's Avatar
ACE81
Guy said that it usually gets damaged when the ignition module is removed or installed. Found that the oil problem is from the rear main seal. Guy said $300-$700 to fix it.
Old Jan 15, 2005 | 05:21 AM
tex94F250's Avatar
tex94F250
Distributor Damaged?
NO, the distributor as a unit doesn't get damaged when a module goes. As Fredrick says, only one moving part. At worst you change the cap/rotor as preventive maintenance. Is the mechanic an individual or a shop? I'd be going back and getting my original distibutor, taking it to a competant mechanic for inspection, and having a short conversation with the owner of the garage. Caveat emptor - Let the buyer beware!
Tex
