Bronco II Ford Bronco II
cv joint grease
Old Jan 13, 2005 | 07:59 PM
SShank42's Avatar
SShank42
cv joint grease
I am replacing the rear cv driveshaft in my 87 with another cv driveshaft out of a 85. Is it possible to grease the factory cv joint.
Old Jan 13, 2005 | 08:46 PM
BumpinB2's Avatar
BumpinB2
Sure is. Just take the boot off and pack some grease in there. You will probably have to get new clamps to hold the boot on though. I think the factory ones are one time use.
Old Jan 14, 2005 | 04:07 PM
SShank42's Avatar
SShank42
What type of clamps would I use. Would I have to worry about the dirveshaft being out of balance.
Old Jan 14, 2005 | 04:13 PM
winddancer's Avatar
winddancer
There are ready made replacement clamps at most autoparts stores. I don't think the balancing will be a problem as the centifical force will even the grease out. Driveshafts are factory balanced as far as I know. But then again, I've been wrong before!
Old Jan 16, 2005 | 08:59 PM
turborich's Avatar
turborich
you can pop the factory clamps off with a screwdriver and a mallet. then put it back on the same way, just be carefull not to tear the boot.
Old Jan 18, 2005 | 02:58 AM
SShank42's Avatar
SShank42
Well it does not matter about the grease. The replacement driveshaft was to long. Just my luck seeing how it was free. Going to buy a new drivershaft when I get off work today. Hopefully this is my problem. I have a popping noise under load that I can here coming from under the vehicle. The boot on the rear cv is split don't know for how long so it need repalced anyway.
