97 expedition
Old Jan 13, 2005 | 06:47 PM
fused's Avatar
fused
97 expedition
Need help with the automatic 4 wheel drive, Light flashes. Tested out my 4 low and 4 high and nothing works. Please help.
Old Jan 13, 2005 | 06:54 PM
Fordlover55's Avatar
Fordlover55
Still kicking!!
Welcome to the site.
Please read the forum guidelines and then the READ FIRST notes in each forum you visit. They'll help you use the site effectively. Thanks for joining us.
Old Jan 20, 2005 | 11:35 PM
mountainman101's Avatar
mountainman101
had similar door ajar switch wire driver door shorted to ground pulled off plugit works too much problem to replace turn on lite with key fob took to deler first they wanted to replace a module my local gas station with a code checter fixed it
Old Jan 21, 2005 | 07:39 AM
Rainman15's Avatar
Rainman15
Common problem. Do a forum search and you should find at least 50 threads regarding this. Normally associated with Vacuum pump failure or linkage rusting issues.
