Sponsored by: Real Truck
which gears and dif?
Old Jan 13, 2005 | 04:29 PM
1badSD's Avatar
1badSD
Question which gears and dif?
Can you tell which gears and which diff you got from the vin #. I'm away from my truck and all I have is the vin #.
Old Jan 13, 2005 | 04:52 PM
Yeti's Avatar
Yeti
What year and config is it?
Old Jan 15, 2005 | 03:49 PM
1badSD's Avatar
1badSD
My truck is an 01 SD CC 4x4
Old Jan 15, 2005 | 04:35 PM
99f350sd's Avatar
99f350sd
engine?-----------------
Old Jan 15, 2005 | 04:41 PM
1badSD's Avatar
1badSD
The engine is the 6.8 v10
Old Jan 15, 2005 | 04:51 PM
99f350sd's Avatar
99f350sd
Dana 50 front, ford 10.5 rear as far as ratio hard to tell 3.73 4.10 or 4.30.
If I had to guess I'd say 3.73 you need to look at the rear tag on the diff.
Old Jan 15, 2005 | 06:00 PM
captchas's Avatar
captchas
Guest
try giving this a post in the v10 area these guys know a lot of specs from the top of their heads, 4x4 v10 my guess is 410's ask the gang there, other wise its on the rear cover on the tag under 1 bolt and on the door sticker in a code number
