Removing Emission Controls
Old Jan 13, 2005 | 01:07 PM
1984BRONCO's Avatar
1984BRONCO
Hey All,
I Have 1984 Full Size Bronco With A 300 Six, I Just Bought It And Don't Know Much About The Six Can Anyone Tell Me What Emission Control Equiptment I Can Remove And Still Have A Good Running Motor?
Thanks, Ryan
Old Jan 13, 2005 | 11:20 PM
bigbrown84truck's Avatar
bigbrown84truck
allow me to put this in caps.... IF YOU REMOVE THE AIR PUMP, REMOVE THE CAT!! you need to leave the heat rise from the manifold to the carb if you live in a cold area or else you will have probs with ur choke and carb. you can leave the charcoal canister on it, it doesn't hurt anything and kinda helps cause all it really does is leave off extra pressure from the gas system.
