Trans Trouble
Old Jan 12, 2005 | 07:04 PM
1 good old boy's Avatar
1 good old boy
Trans Trouble
I'm working on a 92 Explorer and the transmission won't shift out of 1st gear until it's warm. Also the speedo is crazy usually stays pegged. Any suggestions?
Old Jan 12, 2005 | 09:44 PM
mrshorty's Avatar
mrshorty
I would guess the speedo problem is a bad cable.
I would guess the transmission problem is a bad vacuum modulator.
Old Sep 21, 2005 | 04:31 PM
1 good old boy
92 Exployer Now it will not shift into OD. any suggestions?
Old Sep 21, 2005 | 04:48 PM
mrshorty's Avatar
mrshorty
3-4 shift and torque converter clutch lockup are electronically controlled by the EEC-IV computer. Unless there's something obvious from your recent repair work (You did plugg the vehicle speed sensor in after messing with the speedo cable?), start by pulling codes from the computer and inspecting the 3-4 shift/TCC lockup circuits.
