Warranty?
Old Jan 12, 2005 | 05:04 AM
flastroken's Avatar
flastroken
Warranty?
I just took delivery of my 05 SD F-350 and was curious as to the warranty issue if I install a Predator chip in it?
Old Jan 12, 2005 | 07:04 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in this forum are very knowledgeable about these engines; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help to understand more about FTE and how it operates.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read...if you like trucks
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
https://www.ford-trucks.com/forums/s...d.php?t=303583
Enjoy FTE
Do a search on warranty ...here in the 6.0 area!
Old Jan 12, 2005 | 07:12 AM
KurtNJr's Avatar
KurtNJr
Read your Owner's Manuel Supplement for the 05 - it directly addresses the issue of running a tuner. The Predator is not a "chip" and is suppose to remove any trace of its use when the originall program is re-installed - I really doubt this on the 05 but folks smarter than me (maybe) will chime in. Having said all this - you won't break your truck if you run a Predator if you use your head. There is a lot of good information on the 05 Predator thread - read it and make up your mind if you want much better performance with maybe a little risk.
