General Automotive Discussion
Best engine pick
Old Jan 15, 2005 | 04:36 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
Originally Posted by Mil1ion
THe 460 unless it's a 69-71 would be a dog on fuel.
i feel i must argue this slightly,although i will admit that a stock 460 with the motorcraft 4bbl IS a dog on gas, my 460 came from a 78 F-250, it got around 5mpg then, i drove it that way for two years believing thats all it would get, the motorcraft gave up on me and started spewing gas everywhere. so i put my 780 holley vac sec. on the 460 and not only did it breath new life in the engine, it more than doubled my mpg, that is no exageration, i used to drive 45 minutes on I-35 to work everyday, with the motorcraft it took me over a half a tank round trip each day, with the holley i made the same exact trip on only a quarter tank, once again no exageration, i have drivin this truck for 4 years now everyday, doing routine timing and tuneup checks, as long as its all in proper order i get 10-14 mpg depending on my personal driving habits...its a spunky truck and i like to race anything that wants a piece...but when i drive normal and keep my foot out of it, it gets better gas mileage than the fuel injected 350 chebbie truck i sold...please dont take offense mil1on, i just had to tell my personal experience with my 1978 460.......
Old Jan 15, 2005 | 05:51 PM
yield2s's Avatar
yield2s
Originally Posted by ford390gashog
no i think you forgot about the new law 1976 and newer vehicles will never be exempt because of the bill the governer signed.it really sucks so does california laws and taxes
here it is from the dmv website
Not all vehicles must get a Smog Check. Additionally, some vehicles only need a Smog Check when they are being sold or being registered in California after previously being registered in another state. Whether or not a vehicle needs a Smog Check depends on the type of vehicle, the model-year, and the area in which the vehicle is registered.
Some vehicles are exempt from the Smog Check program
Legislation enacted during 2004 made several changes in motor vehicle Smog Check exemptions that will become effective next year. Following is a summary of the revised exemptions and the effective date of each change:
Beginning January 1, 2005, vehicles 6 or less model-years old will be exempt from the biennial Smog Check inspection requirement. For vehicles with registration renewals due in the 2005 calendar year, this exemption includes model-years 2000, 2001, 2002, 2003, 2004 and 2005.
Beginning January 1, 2005, vehicles 4 or less model-years old will be exempt from the Smog Check inspection requirement upon change of ownership and transfer of title transactions with DMV. In 2005, this exemption includes model-years 2002, 2003, 2004 and 2005.
Beginning April 1, 2005, the 30-year rolling exemption will be repealed. Instead, vehicles 1975 model-year and older will be exempt. Therefore, 1976 model-year and newer vehicles will continue to be subject to biennial inspection indefinitely.
Beginning April 1, 2005, vehicles being initially registered in California that were previously registered in another state will be exempt if the vehicle is a 1975 and older model-year vehicle. Newer vehicles, the first 6 model years, are not exempted upon initial registration in California. These vehicles are required to undergo a Smog Check Inspection
thanx for ruining my weekend this really sucks! I guess I'm stuck with the stock form of my engine, and bi-annual inspections.
really though thanks for reminding me how great my states govenment is.
Old Jan 15, 2005 | 08:05 PM
ford390gashog's Avatar
ford390gashog
i know how great it is i live here too it is nothing to write home about it sucks i am moving back south in a few years
Old Jan 15, 2005 | 09:01 PM
tastyklair's Avatar
tastyklair
If your getting a pre 76 truck you are probably best off staying with the type engine that was in it, ie. an FE. That way you don't have to mess with any conversion stuff. Otherwise the 400 when built right is a torque monster.
Old Jan 15, 2005 | 09:10 PM
yaki69's Avatar
yaki69
i have a 300 i6 in a 79 truck witha 3 on tree. it works just fine for a daily driver and strret/strip racer. it came with a 302 originally, but if i had the money to pick, id go with a 390 . the 390 has the high hp if built right along with the torque for street/strip use.
Old Jan 15, 2005 | 09:29 PM
yaki69's Avatar
yaki69
hey ive got a 1979 f100 with a 300 I6 and i get 14-16 in town and 16-20 on the highway. no exxageration. ita all stock except for a new electronic choke carb. its a 3 on tree and it'll scooot just like a new one.
Old Jan 15, 2005 | 10:01 PM
Dan7378's Avatar
Dan7378
Originally Posted by jpb222
I'd find the truck with the nicest body/frame/interior/paint and upgrade the engine later if you need to/want to. Engine swaps are easier and cheaper than bodywork
Very true.I'm doing the bodywork on my truck right now and its taking A LOT longer than the mechanical work I've done on it.
Dan
Old Jan 16, 2005 | 12:19 AM
Huntersbo's Avatar
Huntersbo
My Friend retired military; has a F-100 with a 360 Edlebrock automatic 6" lift in the front and 4" in the back he gets 5 miles per gallon whether he drives fast or slow, this thing will outrun rice rockets he says.
My friend's '95 F-350 4x4 auto 460 crew cab 8' bed stock has out run Honda civics, I remember when we raced one with 4 cuys 700 lbs total of passenger weight in his truck, the civic had exhaust and I do not know what else.
I wonder if it is worth it milling the head on a 360, I wonder what a 360 can do with 10:1 comp .500" lift 210 D @ .50 and 110 lobe seperation angle.
I noticed at Edlebrock website the 390 out torques the 400 I wonder which has more potential
Old Jan 16, 2005 | 03:07 AM
Hypoid's Avatar
Hypoid
My '74 F-100 four wheel drive came with a 390 4V, dual exhaust, manual transmission, 3.55 R&P, 31" tires.
Work or play, city or highway, it averaged 10 to 12 MPG. Anything less and it was time for a tune-up.
Never been dissapointed in the FE.
Mike
Old Jan 16, 2005 | 02:22 PM
Barney Oldfield's Avatar
Barney Oldfield
I have a 1976 supercab 2wd with a built 390, holley 650vac secondaries,k&n,edelbrock performer intake, flowmaster dual 2.5 exaust and stock duraspark ignition. It gets 12 mpg and hauls butt.I love the FE so good luck.
Old Jan 16, 2005 | 07:28 PM
android7105's Avatar
android7105
recently bought a 79 f150 4x4 w/ the 400 and have no complaints. it has all the power i need. however i have heard stories of problems w/ the oiling systems
Old Jan 16, 2005 | 07:50 PM
jrsroadhauze's Avatar
jrsroadhauze
Im runnin a 390 with early GT heads and a 750 holley on top of a Edelbrock performer manifold. I have to burn 91 octane and disconnect the vacuum advance if I'm going to nail the pedal. This truck weights in at 5800 lbs. the rear end is a D60 3.54 with 33x12.50x16.5s It will tow anything. On a good day cruzin at 65 on flat ground with no load it will get 11mpg. The 750 holley is a little to big. I had a friends 600 cfm Holley on it and it had more touque. Ive got the same problem with the CA smog rule and was hoping to register the truck in CA this year. My future plans are to pull the 390 and install it in my 50 ford coupe and build a twin turbo propane powered 460 for the truck. I also have a 64 f-100 that I'm building with a 71 460 with a 2.74 rear and C-6. Hope to get 15mpg with that one.
Old Jan 16, 2005 | 08:12 PM
  #28
zwinstead's Avatar
zwinstead
I have 400 bored .030, Comp 268 Cam, Holley 750 Double Pumper, headers, 2.5 dual exhaust w/Flowmasters, Edelbrock Performer Int and I love it. More than enough power to tow my other Ford truck on a trailer through the mountians and it doesn't ping even on 87 octane because I left the compression ratio at 8:1.
Old Jan 16, 2005 | 08:22 PM
  #29
Mil1ion's Avatar
Mil1ion
This thread will now be moved to the GAD forum as it contains all engine discussion
There isn't any relation to the 73-79 Topics
