Drilling for pyrometer
Old Jan 11, 2005 | 10:35 PM
fordberg's Avatar
fordberg
Exclamation Drilling for pyrometer
I had a thought. When installing a pyrometer by drilling the exhaust manifold, just before drilling through the pipe start the engine to pressurize the hole. All the drill filings will fly outward. Make sure your air cleaner is on and watch the heat.
Old Jan 11, 2005 | 11:08 PM
jesse460's Avatar
jesse460
When I drilled mine I left it run, Just be sure to wear gloves when you break through its hot.
Old Jan 11, 2005 | 11:09 PM
Kwikkordead's Avatar
Kwikkordead
Good idea! As an added bonus: jam a large rag up the tailpipe to create a lot of backpressure and really blow the chips out.
Old Jan 12, 2005 | 01:49 AM
rprhyno's Avatar
rprhyno
Thumbs up
I drilled mine with the engine off, but used one of those extendable magnet pick-up tools to probe into the manifold and remove the chips. It worked great and I didn't have to worry about anything getting into the turbo.
Old Jan 12, 2005 | 06:09 AM
01f350's Avatar
01f350
I did the magnet method with the engine off, worked just fine.
Old Jan 12, 2005 | 08:05 AM
blackf3504dr's Avatar
blackf3504dr
You also may want to put a coating of grease on the drill bit , it will help the metal chips stick to it . Although I like kwikk's answer !! LOL !
