Rebuild?
Old Jan 11, 2005 | 07:29 PM
351ballsofford's Avatar
351ballsofford
Rebuild?
How much does it cost to rebuild a 351w engine? i'm considering doing it since its winter and i have another car to drive. what all should i rebuild
Old Jan 11, 2005 | 08:43 PM
RLKBOB's Avatar
RLKBOB
I can give you an idea of what I paid but you need to call a machine shop near you to get a quote.
bore/hone: $80
grind crank: $110
hot tank/magnaflex: $45
r/r cam bearings: $35
r/r freeze plugs: $30
balance rotating assy: $200
assemble short block: $275
these are all labor charges, all your new parts are more, I got new rods but you could have your reconditioned(more labor), need new pistons, rings, bearings, freeze plugs, cam and lifters(recommended), timing chain, oil pump and pick up tube, rod bolts and main cap bolts and all new gaskets. This is just the short block you still need to do the heads, should give you an idea though.
Old Jan 11, 2005 | 08:57 PM
MBDiagMan's Avatar
MBDiagMan
When rebuilding an engine, you can NEVER know just how extensive the rebuild will be until you take it apart. When you start micing cylinder walls, and crankshaft, then you'll know more.
To begin with, why are you rebuilding it? Have you done a compression and cylinder leakdown test?
Good luck,
Doc
ASE Master
Old Jan 11, 2005 | 11:43 PM
termyt00's Avatar
termyt00
go for the 408 stroker ... it will cost some eXtra cash but it is really worth it... a good rebuild on the 351 will set you back about a grand. is it a EFI or CARB?
Old Jan 12, 2005 | 04:37 AM
ALSAIR's Avatar
ALSAIR
I got my re-build kit from Summit. She is completed and runs incredible. The kit was around $470. It came with everything needed for a complete re-build minus the cam.
Al
Old Jan 15, 2005 | 08:25 PM
351ballsofford
my trucks efi. it could use it but she's still a beast. I've just been curious what it would cost me to do the job. I probably wont being doing this soon i've got other things i wanna do first.
Old Jan 16, 2005 | 06:12 AM
MustangGT221's Avatar
MustangGT221
I don't even know if anyone could tell you how much it would cost.
My project ended up being more than twice as much as I expected.
Usually, ya get a rough idea how much it will cost, then double that figure to get a more realisitic one. You'll get nickled and dimed to death on projects like these, even just the gas to the machine shop somewhat counts.
Old Jan 16, 2005 | 10:58 AM
captainkirk's Avatar
captainkirk
I rebuilt the 351 W in my truck over the summer and I was suprised it didn't cost more. I had the entire engine together for $1300 and that includes a $570 Edelbrock power pack (intake, carb, cam+lifters). I had the block and heads cleaned, new valve guides, new crank and cam bearings, magnafluxed heads, new +.030 pistons, full ring set, the cylinders bored, and the pistons intstalled on the rods all for a little over $650 including the labor. If you shop around, you will be able to find a good price. Try to find a nice family owned place; they always do an outstanding job and they rarely overcharge. As for the 408 in. stroker idea, check with Summit for the crank because I believe it was only $dollars as well. Make sure to take it to the machine shop to get the proper clearances though.
Old Jan 16, 2005 | 12:02 PM
termyt00's Avatar
termyt00
my PAW stroker was a complete short block listed for $2495! with worked heads it was $2995 that was in '99! the new '04 catalog does'nt list a 427, it is replaced by a 408, 418,(the difference being the bore) the new 408/418 have a 4340 steel crank now. i think the price is still the same, the catalog is at dads house,he is looking to order the 408 for his '87! which is not a bad price bad for a complete block assembly!i don't think you can peice it together your self for less.
...IFyou decide to go this route let me know! i'll share some pointer's i learned for dabbling with mine! it is really a GOOD engine!
