Starter Problem ????
Old Jan 11, 2005 | 04:54 PM
96f350rcsrw460zf's Avatar
96f350rcsrw460zf
I can't figure this out. I had my starter off for some exhaust mods. I put it back on just as it was. No problems. Now every other time I try to start it I get a "thunk" noise on the first try. The second try always works. It sounds like the starter gear is hitting the flywheel instead of the teeth meshing. The truck ( 1996 460 ) sits in the garage for long times between starts. The battery is well charged. The truck is all original with 14,000 miles. Any ideas ????
Old Jan 11, 2005 | 08:41 PM
mark a.'s Avatar
mark a.
I would start with taking the starter back off & cleaning it & the bell housing up where they go together.
Old Jan 14, 2005 | 09:38 AM
96f350rcsrw460zf
I will check that but under the hood is clean enough to lick. The truck has never been rained on or even dirty. Thanks
Old Jan 20, 2005 | 05:04 PM
96f350rcsrw460zf
I did unbolt the starter and check. It is clean and they bolt together tight.
Old Jan 20, 2005 | 06:33 PM
mark a.'s Avatar
mark a.
Maby the clip came off the end of the starter shaft.
