Tow Hitch Upgrade
Old Jan 11, 2005 | 01:15 PM
aph453's Avatar
aph453
Tow Hitch Upgrade
Hey Guys and Gals,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
My question. I have a 2002 Ford Escape that I just recently purchased. It has the class 2 or 1 (I believe?) Hitch. I traded in my Ranger which had the class three Hitch. Shortly before I got the escape my better half bought me this awesome hitch cover. It's an LED Ford Symbol that lights up when you apply the brakes/turn the lights on. Any who, I want to put this on the Escape so I would like to know how hard it is to swap the Hitch I have now for a Class 3 hitch. How hard would running the electrical stuff be? I don't tow anything and probably never will, this is strictly so I can use the Hitch cover (it is special to me). Thanks<o></o>
<o></o>
Adam
Old Jan 11, 2005 | 01:49 PM
grafekie's Avatar
grafekie
You may not be able to use the same hitch as the Ranger, but adding a hitch isn't too hard. A class I or II is a different type of hitch, and may be mounted to the body, the bumper, or the frame. If its the frame its easiest to remove it. Just order a new one (or find out if the old one will fit) and bolt it on. You should have the 4 pin wiring already in place if it came with a hitch from the factory. Good luck!
Old Jan 11, 2005 | 03:53 PM
jschira's Avatar
jschira
All you need is one of these 1-1/4" (Class I) to 2" (Class III) adapters:
http://www.etrailer.com/Merchant2/me...tegory_Code=HA
Old Jan 11, 2005 | 08:55 PM
SoCalDesertRider's Avatar
SoCalDesertRider
You can also get a class 3 hitch for it at the Etrailer website, if a class 3 is made for the Escape.
Old Jan 12, 2005 | 08:52 PM
aph453's Avatar
aph453
Thanks for the response guys. I don't think I will get an adapter for it, it seems as if it would stick to far out for my comfort. I did check that site out and they do make class 3 for the Escape. I'll have to modify the heat shield slightly.
Adam
